- 19 Mar 2007
- 11.803
- 596
mmcamd es un Emulador de softcam y un cliente Card-Sharing de Newcamd Cliente y CCcam Cliente
Esta en fase beta y os copio lo que indica su propio creador, esta incluido en los últimos plugins para spark
mmcamd is a SoftCam Emulator and Card-Sharing Client.
As SoftCam Emulator it supports following Systems:
seca1
viaccess2.3 + viaccess2.6
ndz
and as Card-Sharing Client it supports Newcamd Client and CCcam Client (CCcam client is experimentel) without EMM support.
needed file are: mmcamd.cfg and SoftCam.Key (SoftCam.Key format is the same mgcamd and CCcam SoftCam.Key Format) you need to copy it to /var/keys
History:
25062010
*- add csat (astra)
02092009
fix capmt() s(till some bugs on enigma platform)
newcamd-bug fixes (try to reconnect by ecm change)
config file it called now mmcamd.cfg, with following format:
newcamd clients
N: my_domain.com 123456 user pass 01 02 03 04 05 06 07 08 09 10 11 12 13 14
14102009
add biss_dcw (mgcamd biss key format, not tested)
add CCcam protokoll support (experimentel) (thx to __silencer)
to test it set in mmcamd.cfg CCcam_client value to 1 and add your C line in following format:
C: my_domain.net 123456 user pass
19102009
some minor fixes:
pmt parsing
ecm-request
22102009
fix constant cw(biss)
28102009
add descrambler delay
config file updated.
19012010
add viaccess2.3
add viaccess2.6 (SCT/BIS)
250110
Fix ART camd
30012010
CCcam Client minor fixes
140210
fix sigpipe bug
TigreTunisie
