CCcam info de kanber_kav
tinos
26 Mar 2009
52
He visto esta tool en satpimps para el CCC. Creo que coge el listado de tarjetas de /tmp
gorski
10 Abr 2009
1.334
9
CCcaminfo for AzboxHD
For FW v. 2032
Telnet /camd/CCcaminfo and give it the rights -> CHMOD to 755
Thanx to kanber_kav!!!
gorski
10 Abr 2009
1.334
9
The info for the one Tinos put up, that is the "How to..." by me... :grin:
Unpack, no need to install anything on your PC.
Start the programme [AZboxHDCCcam.exe] by double clicking on it... :thumbsup:
Click on Box Settings -> AZbox HD Login.
Put your AZbox HD's IP address [like 192.168.x.x] + pass [= azbox] -> OK.
Click on Online Card, then Connect on the left side and then on Refresh, lower left....
Now you see it... or you don't... well, you do see which cards are on your peer's "menu"...
Maybe you can even open a few channels... depending on how "close" to him you are...... and if CCcam for AZbox HD "works" with them... hehe..
P.S. You can even edit your .cfg file, add or remove servers etc. CCcam -> CCcam.cfg Edit -> File Read -> click on a server/peer -> edit at the bottom -> use the buttons as appropriate and even UP into your AZbox HD when you're done etc. etc.:have a nice day:
gorski
10 Abr 2009
1.334
9
Tinos, m8: can we give KK a VIP status, please... ;)
chiripa_kdt
22 Ene 2009
164
he metido la carpeta en /camd/CCcaminfo y dado atributos a 755 a todos los ficheros, pero en la pantalla no me sale absolutamenta nada. y si q hay datos en /tmp/cccam.info
CardID 477 at xxxxxxxx.dyndns.biz Card 4A700000 handler 41872700 uphops 3 maxdown 0
CardID 478 at xxxxxxxx.dyndns.biz Card 4A700000 handler 94422700 uphops 3 maxdown 3
porque no veo ninguna informacion en la pantalla?
en una de las imagenes q habeis puesto, se ve en la parte inferior como dos botones:http://img189.imageshack.us/img189/7746/dc090607003.jpg
- cccam.info read y
- reset camd, que a mí no me aparecen
que puedo haber hecho mal??
dveras
28 Abr 2009
913
30
me pasa exactamente igual que tu. sale solo la imagen que dices con los dos botones que no hace nada el azul el otro resetea cccam o los datos. Pero sin llegar a mostrar nada en la pantalla.
gorski
10 Abr 2009
1.334
9
I realised I must do:
1) YELLOW button -> OK
2) OK button -> OK.
Then it works.
If I'm lucky...
gorski
10 Abr 2009
1.334
9
Waiting for the properly debugged 2238!!! :have a nice day:
Soon, I am told...:Psmiley:
