- 10 Abr 2009
- 1.334
- 9
0) I installed it, after renaming it to patch.bin, putting it on a USB stick and... :grin:
Didn't perform the "clean install", i.e. without "formatting the application area". I just did it on top of - or should I say beside- everything that was in already...
It took quite a while to reboot after the install...
When it did:
1) I disabled all camd/PLUG-INS by putting # sign in front of them.
2) Home -> Plug-ins -> OpenXCAS -> Download Executable -> azboxworld link didn't have the newest MultiCAS to download and install and neither did islaremota or satelitesinfo -> so I got out...
3) FileZilla -> deleted the old and then put in the newest MultiCAS module and openxcas.conf, gave CHMOD to 755 to the module and rebooted....
4) Activated MultiCAS by removing # in front of it, went to Camd Setup -> MultiCAS -> Smartcard Interface -> Card Splitter & CS to check I am connected to my peer's servers [login successful! :have a nice day:], went out [Exit] -> it asked me if I want to log into all the servers... and took it out for a spin... :thumbsup:
5) Still necessary to press the OK button on your remote to get to the channels list [not good!]...
6) French package [19'E] opened but it was stumbling at first... Then it was OK. :have a nice day:
Spanish one [19'E] had hiccups, too. Both were slow to open, sadly! But worked OK after the initial hiccup or two! So far so good!
Total TV [16'E] was faster to open and worked fine. My Croat subtitles kicked in nicely. All fine!
Albanian package is also cool. C+NL was fine, too. Opening faster. Stable.
On 28'E [guess which package :grin:] some hiccups but that was to be expected. Worked, though and for my tastes - just about watchable... If sub-t is activated one can follow it well enough, I think.
Thor C+ was cool!
Etc. etc.
It's just a quick test but it seems fairly good at this point.
Mbox will be tested a bit later....
7) YouTube: U2 at Rose Bawl was great! :have a nice day:
8) Oh, yeah, forgot to check the Settings for novelties: Internet LAN speed is the SAME as before, sorry... Not good!
TV Channel -> IP channels -> 2 modes: HTTP [go down to TV Type -> move to the right > you get Kartina TV and you see the example, how to add more IP TV channels] and UDP. One can add details via remote and Save. Really cool!!! Getting better!
9) Streaming from PC to AZbox HD was difficult, whatever I tried, Movies or Music: first to recognise the workgroup/home network - I had to reboot - and i still wouldn't kick in. I must reboot the laptop, as well and see...
It worked but my "Gilberto Gil Live" .mkv doesn't work ["not supported", it says]. "House" [3rd season] .avi is OK.
10) FTP -> as before "fail to connect error"... It NEVER worked so far - for me...
11) RSS works but VERY slow... Bad!!! Btw, couldn't play media - "you do not have the correct version of flash player", as before...
12) Browser: slow... As above, of course... Plus, the cursor is on the LEFT side of the letter you just typed in, as you wanna put in a link to go to. Ridiculous! It works like that, too but... Press OK -> you do not go to the link but to the GO button, so one more press on OK needed. Unnecessary, it seems...
One can to YouTube from the browser [next to gmail, if you are in Google page] -> tried playing Ibrahimovic's goal and
Excruciatingly slow to load he page!!! It cannot do it - "Object"... Go to Adobe site and try to install it... Hehe... Oh, well... Too much to ask for - still... Hmmm... Nada! Nextttt... [It worked in YouTube Player, of course...]
13) EPG plug-in [thanx Blu!!!]:
Start your PuTTy [telnet], log in and type this in:
then reboot!!!
GO TO PLUGINS MENU AND THERE YOU WILL SEE THE PLUGIN ACTIVE!!!! THE EPG FOR 3 DAYS ON FREESAT, UK AND ITALY!!!
I pressed Receive EPG on S k y IT for just 1 day. Memory was on 7MB!!! Then press "Receive"... It was stuck on 30%. I increased it to 15MB and it got stuck again. This time on 15%. When I put 17MB - it got stuck once again, at 13%. Rubbish!!!:yuush:
This needs improving, Opensat! [I presume it's them, not Blu!]
16'E -> Total TV -> RTS 1 and 2 -> 7 day EPG IS WORKING without the plugin!!!! How come? What's the difference, would you know?
14) It feels better! :have a nice day:
==================GOOGLE TRANSLATION================
0) He instalado, después de cambiar el nombre a patch.bin, poniéndolo en una memoria USB y ...
No realizar la "instalación limpia", es decir, sin "el formato de la zona de aplicación". Yo sólo lo hizo en la parte superior de - o quizás deberÃÂÂa decir-junto a todo lo que ya estaba en ...
Le tomó un buen tiempo para reiniciar el sistema después de la instalación ...
Cuando lo hizo:
1) He desactivado todas las UME / PLUG-INS poniendo signo # delante de ellos.
2) Inicio -> Plugins -> OpenXCAS -> Descargar ejecutables -> link azboxworld no tenÃÂÂan la más reciente MultiCAS para descargar e instalar y tampoco islaremota o satelitesinfo -> por lo que salà...
3) FileZilla -> suprimido el antiguo y luego puesto en el nuevo módulo de MultiCAS y openxcas.conf, dio a CHMOD 755 a los del módulo y reiniciar ....
4) MultiCAS activado mediante la eliminación de # delante de él, fue a camd Setup -> MultiCAS -> Interfaz de tarjeta inteligente -> Tarjeta Splitter & CS para comprobar estoy conectado a los servidores de mi Peer [ingresar con éxito! ], Salió en [Salir] -> me preguntaron si quiero acceder a todos los servidores ... y se lo llevó a dar una vuelta ...
5) sigue siendo necesario pulsar el botón OK en el control remoto para acceder a la lista de canales [no es bueno !]...
6) el paquete francés [19'E], se abrió pero se tropieza al principio ... Entonces estaba bien.
Español uno [19'E] tenÃÂÂa hipo, también. Ambos fueron lentas para abrir, por desgracia! Pero trabajó en Aceptar después de la hipo inicial o dos! Hasta ahora todo bien!
Total TV [16'E] fue más rápido para abrir y funcionó bien. Mi subtÃÂÂtulos en croata comenzó muy bien. Todos van bien!
Paquete de Albania también es genial. C + NL estaba bien, también. De apertura rápida. Estable.
El 28'E [supongo que paquete] algunos tropiezos, pero que era de esperar. Trabajado, sin embargo y para mi gusto - casi watchable ... Si la sub-T se activa se puede seguir bastante bien, creo.
Thor C + was cool!
Etc etc
Es sólo una prueba rápida, pero parece bastante buena en este punto.
Mbox se pondrá a prueba un poco más tarde ....
7) YouTube: U2 en el Rose Bawl was great!
8) ¿Ah, sÃÂÂ, se olvidó de comprobar la configuración de novedades: Internet de alta velocidad LAN es la misma que antes, lo siento ... No es bueno!
Canal de TV -> Canales de IP -> 2 modos: HTTP [ir a Tipo de TV -> Mover a la derecha> te Kartina TV y vea el ejemplo, cómo añadir más canales de televisión IP] y UDP. Se puede añadir detalles a través de remotas y Guardar. Really cool! Getting better!
9) Streaming desde la PC a Azbox HD fue difÃÂÂcil, lo he intentado, pelÃÂÂculas o música: en primer lugar a reconocer el grupo de trabajo / red - tuve que reiniciar - y todavÃÂÂa no se produzca, que debe reiniciar la computadora portátil, asày ver ...
Funcionó, pero mi "Gilberto Gil en vivo". Mkv no funciona [ "no compatible", dice]. "House" [3 ª temporada]. Avi está bien.
10) FTP -> como antes "no se pueda conectar de error" ... Nunca funcionó hasta ahora - para mà...
11) funciona el RSS pero muy lento ... Bad! BTW, no podrÃÂÂan desempeñar los medios de comunicación - "no tiene la versión correcta de Flash Player", como antes ...
12) Navegador: lento ... Como el anterior, por supuesto ... Además, el cursor se encuentra en la parte izquierda de la carta que acaba de escribir en el, como usted quiere poner en un enlace para ir a. ¡RidÃÂÂculo! Funciona asÃÂÂ, también, pero ... Pulse Aceptar -> no ir al enlace, sino en el botón GO, asàque uno más de prensa sobre Aceptar necesario. Innecesaria, que parece ...
Uno puede a YouTube desde el navegador [siguiente a Gmail, si usted está en la página de Google] -> intentado jugar objetivo Ibrahimovic y
Extremadamente lento a la página se carga! No puede hacerlo - "objeto" ... Ir a la página web de Adobe y tratar de instalarlo ... Hehe ... Oh, bueno ... Demasiado pedir para - aún ... Hmmm ... Nada! Proxima... [Se trabajó en YouTube Player, por supuesto ...]
13) EPG plug-in [thanx Blu !!!]:
Consulta tu masilla [telnet], y el tipo de registro en esta en:
a continuación, reinicie!!!
Ir a Plugins MENU Y NO PODRàVER LA PLUGIN ACTIVE!! El EPG PARA LOS 3 DIAS DE FREESAT, Reino Unido e Italia!
He pulsado Recibir EPG en k S y de TI por sólo 1 dÃÂÂa. La memoria era el 7MB! A continuación, pulse "Recibir" ... Se quedó atorado en el 30%. I aumentó a 15 MB y se atascó de nuevo. Esta vez, el 15%. Cuando puse 17MB - que quedó atrapado una vez más, en el 13%. Basura!
Esto debe mejorar, OPENSAT! [Supongo que son ellos, no Blu!]
16'E -> Total TV -> RTS 1 y 2 -> 7 dÃÂÂas EPG funciona sin el plug-in!!! ¿Por qué? ¿Cuál es la diferencia, lo sabes?
14) Se siente mejor!:have a nice day:
When it did:
Thor C+ was cool!
Etc. etc.
mkdir -p /PLUGINS/EURO_EPG
then reboot!!!
Cuando lo hizo:
Thor C + was cool!
Etc etc
mkdir -p /PLUGINS/EURO_EG
