Vu+ Solo 4K Problema IP fija y skins
LeoBaker
apernilado
12 Abr 2016
17
Buenas,
Versión de OpenSpa:
6003
Tengo openbh en flash, y varias imágenes en multiboot.
He puesto ésta última, 6.0.003, arranca correctamente. Le cambio la ip, reinicio y se queda en negro.
Características especiales:
OPENSPA en multiboot
Se adjunta Crash-log: Si/ No
Si
Entro por ssh, como habéis indicado, init 4 y esta es la salida después de ejecutar enigma2:
root@vusolo4k:~# enigma2
PYTHONPATH: /usr/lib/enigma2/python
DVB_API_VERSION 5 DVB_API_VERSION_MINOR 10
ENIGMA2_DEBUG settings: Level=3
/dev/fb1: No such file or directory
framebuffer not available.
consoleFd 10
EVIOCGRAB: Device or resource busy
executing main
NXPL_RegisterNexusDisplayPlatform data->hwInterface 0xb3f025f8
< 269.437> [Harddisk] enumerating block devices...
< 269.441> new Harddisk sda -> /dev/sda -> /dev/sda
< 269.462> [Harddisk] enumerating network mounts...
< 269.484> loading display skin skin_display.xml
< 269.663> Reading satellites.xml
< 270.054> sec config cleared
< 270.055> link tuner 1 to tuner 0
< 270.056> slot: 0 configmode: simple
< 270.056> diseqcmode: single
< 270.057> slot: 1 configmode: loopthrough
< 270.057> slot: 2 configmode: simple
< 270.057> diseqcmode: diseqc_a_b
< 270.057> slot: 3 configmode: simple
< 270.057> slot: 4 configmode: simple
< 270.058> slot: 5 configmode: simple
< 270.058> diseqcmode: diseqc_a_b
< 270.058> slot: 6 configmode: simple
< 270.058> slot: 7 configmode: simple
< 270.058> sec config completed
< 270.059> [NimManager] slotname = Tuner A, slotdescription = Vuplus DVB-S NIM(7376 FBC), multitype = False
< 270.059> [NimManager] slotname = Tuner B, slotdescription = Vuplus DVB-S NIM(7376 FBC), multitype = False
< 270.059> [NimManager] slotname = Tuner C, slotdescription = Vuplus DVB-S NIM(7376 FBC), multitype = False
< 270.059> [NimManager] slotname = Tuner D, slotdescription = Vuplus DVB-S NIM(7376 FBC), multitype = False
< 270.059> [NimManager] slotname = Tuner E, slotdescription = Vuplus DVB-S NIM(7376 FBC), multitype = False
< 270.059> [NimManager] slotname = Tuner F, slotdescription = Vuplus DVB-S NIM(7376 FBC), multitype = False
< 270.059> [NimManager] slotname = Tuner G, slotdescription = Vuplus DVB-S NIM(7376 FBC), multitype = False
< 270.059> [NimManager] slotname = Tuner H, slotdescription = Vuplus DVB-S NIM(7376 FBC), multitype = False
< 270.077> [Picon] adding path: /usr/share/enigma2/
< 270.102> [Picon] adding path: /media/sda1/picon/
< 270.347> [ML] BlurayPlayer not installed: cannot import name BlurayPlayer
< 270.483> [Time By]: Transponder
< 270.754> [iInputDevices] getInputDevices <ERROR: ioctl(EVIOCGNAME): [Errno 22] Invalid argument >
< 270.754> [iInputDevices] getInputDevices <ERROR: ioctl(EVIOCGNAME): [Errno 25] Inappropriate ioctl for device >
< 270.771> Activating keymap: Default (US)
< 270.772> [ePopen] command: loadkmap < /usr/share/keymaps/default.kmap
< 270.773> Activating language Español
< 270.936> [VideoMode] setting aspect: 16:9
< 270.937> [VideoMode] setting wss: auto
< 270.937> [VideoMode] setting policy: panscan
< 270.938> [VideoMode] setting policy2: letterbox
< 271.052> [VideoMode] setting scaler_sharpness to: 0000000D
< 271.053> [VideoMode] setMode - port: HDMI, mode: 1080p, rate: multi
< 271.164> [keymapparser] keymap file /usr/share/enigma2/keytranslation.xml not found
< 271.168> [ePopen] command: ip -o addr show dev wlan0
< 271.169> [ePopen] command: ip -o addr show dev eth0
< 271.301> Setting OSD position: 0 720 0 576
< 271.301> Setting OSD alpha: 255
< 271.302> Setting 3D mode: auto
< 271.310> Setting 3D depth: 50
< 271.329> Plugin Extensions/WebInterface failed to load: No module named plugin
< 271.329> Plugin probably removed, but not cleanly in /usr/lib/enigma2/python/Plugins/Extensions/WebInterface
< 271.427> [OpenSPAPlug] set language to es
< 271.429> [OpenSPAPlug] set language to es
< 271.437> [Ipkg] Added to OPKG destinations: /media/sda1
< 272.899> [RemoteControlCode] Write Remote Control Code : 2
< 272.973> [DeviceManager] fallback to default translation for: Device Manager
< 272.974> [DeviceManager] fallback to default translation for: Format/Partition your Devices and manage Mountpoints
< 272.976> [DeviceManager] fallback to default translation for: Device Manager - Fast Mounted Remove
< 272.977> [DeviceManager] fallback to default translation for: Quick and safe remove for your mounted devices
< 273.041> [NetworkBrowser] fallback to default translation for NetworkBrowser
< 273.042> [NetworkBrowser] fallback to default translation for Search for network shares
< 273.043> [NetworkBrowser] fallback to default translation for MountManager
< 273.044> [NetworkBrowser] fallback to default translation for Manage network shares
< 273.045> [NetworkBrowser] fallback to default translation for Mount again
< 273.046> [NetworkBrowser] fallback to default translation for Attempt to mount shares again
< 273.047> [NetworkBrowser] fallback to default translation for Mount shares again
< 273.048> [NetworkBrowser] fallback to default translation for Attempt to mount shares again
< 273.308> [spzCAMD] Started
< 273.348> [EPG download MediaHighway] Starting up Version
< 273.753> [TranscodingSetup] set /proc/stb/encoder/enable to enable
< 273.754> [TranscodingSetup] set /proc/stb/encoder/0/bitrate to 2000000
< 273.754> [TranscodingSetup] set /proc/stb/encoder/0/framerate to 50000
< 273.755> [TranscodingSetup] set /proc/stb/encoder/0/display_format to 480p
< 273.755> [TranscodingSetup] set /proc/stb/encoder/0/aspectratio to 2
< 273.756> [TranscodingSetup] set /proc/stb/encoder/0/audio_codec to aac
< 273.756> [TranscodingSetup] set /proc/stb/encoder/0/video_codec to h264
< 273.757> [TranscodingSetup] set /proc/stb/encoder/0/gop_frameb to 0
< 273.757> [TranscodingSetup] set /proc/stb/encoder/0/gop_framep to 29
< 273.757> [TranscodingSetup] set /proc/stb/encoder/0/level to 3.1
< 273.758> [TranscodingSetup] set /proc/stb/encoder/0/profile to baseline
< 273.759> [CI_Assignment] activating ci configs:
< 273.759> [CI_Activate] FOUND 2 CI Slots
< 273.760> [CI_Activate_Config_CI0] no config file found
< 273.760> [CI_Activate_Config_CI1] no config file found
< 273.784> [SKIN] Parsing embedded skin <embedded-in-'VBMain'>
< 273.805> [SCREENNAME] ['VBMain_summary', 'SimpleSummary']
< 273.806> [SCREENNAME] VBMain
< 274.249> [spzCAMD] Started
< 274.501> [Skin] Error: {confluence_openspa/skin.xml}: pixmap file /usr/share/enigma2/distro-logo.png not found!. Please contact the skin's author!
< 274.592> [Picon] adding path: /usr/share/enigma2/
< 274.613> [Picon] adding path: /media/sda1/picon/
< 274.886> [SCREENNAME] SecondInfoBar
< 275.127> [Skin] Attribute not implemented: xposDuration value: 185
< 275.127> [Skin] Attribute not implemented: colorDate value: teal
< 275.127> [Skin] Attribute not implemented: colorDuration value: gris40
< 275.127> [Skin] Attribute not implemented: colorEvent value: frgr
< 275.133> [Skin] Attribute not implemented: xposEvent value: 200
< 275.133> [Skin] Attribute not implemented: xcolorBegin value: tealclaro
< 275.133> [Skin] Attribute not implemented: render value: Label
< 275.203> [SKIN] No skin to read...
< 275.203> [SCREENNAME] RdsInfoDisplaySummary
< 275.237> warning, skin is missing element pixstateplay in <class 'Screens.PVRState.TimeshiftState'>
< 275.237> warning, skin is missing element pixstatepause in <class 'Screens.PVRState.TimeshiftState'>
< 275.247> RemovePopup, id = ZapError
< 275.408> [SCREENNAME] RdsInfoDisplay
< 275.422> [Skin] Error: {confluence_openspa/skin.xml}: pixmap file /usr/share/enigma2/record.png not found!. Please contact the skin's author!
< 275.423> [SCREENNAME] InfoBarSummary
< 275.425> [SCREENNAME] TimeshiftState
< 275.428> [SCREENNAME] InfoBar
< 275.515> [Skin] Attribute not implemented: alphatest value: blend
< 275.568> setValue 50
< 275.606> [NTP]: setting E2 unixtime: 1466299988.97
< 275.606> [NTP]: setting E2 realtime: Sun Jun 19 03:33:08 2016
< 275.770> [ePopen] command: route -n | grep wlan0
< 275.779> [ePopen] command: route -n | grep eth0
< 275.852> 0.0.0.0
< 275.852> 192.168
< 275.865> AT plugin not found
< 275.865> SerienRecorder plugin not found
< 275.865> ER plugin not found
< 275.886> [OpenWebif] no plugins to load
< 275.891> [OpenWebif] started on 80
No tengo video en la tele, he probado varias veces la instalación y en el primer reinicio ocurre esto, tanto si solo cambio la ip como si le meto canales, que era lo que pensaba que fallaba. Sin embargo si tengo control por webif... Desde ahí he probado también a cambiar la resolución y sigue en negro.
Control + C para parar enigma2 y sale esto (por si os sirve de más ayuda)
C< 828.147> connectionLost? [Failure instance: Traceback (failure with no frames): <class 'twisted.internet.error.ConnectionLost'>: Connection to the other side was lost in a non-clean fashion: Connection lost.
]< 828.147>
< 828.388> [TranscodingSetup] set /proc/stb/encoder/enable to enable
< 828.389> [TranscodingSetup] set /proc/stb/encoder/0/bitrate to 2000000
< 828.389> [TranscodingSetup] set /proc/stb/encoder/0/framerate to 50000
< 828.390> [TranscodingSetup] set /proc/stb/encoder/0/display_format to 480p
< 828.391> [TranscodingSetup] set /proc/stb/encoder/0/aspectratio to 2
< 828.391> [TranscodingSetup] set /proc/stb/encoder/0/audio_codec to aac
< 828.392> [TranscodingSetup] set /proc/stb/encoder/0/video_codec to h264
< 828.392> [TranscodingSetup] set /proc/stb/encoder/0/gop_frameb to 0
< 828.393> [TranscodingSetup] set /proc/stb/encoder/0/gop_framep to 29
< 828.393> [TranscodingSetup] set /proc/stb/encoder/0/level to 3.1
< 828.394> [TranscodingSetup] set /proc/stb/encoder/0/profile to baseline
Ocurre sólo cuando le pongo la ip fija. Cuando arranco con dhcp parece que va bien.
Muchas gracias por todo el curro que os pegais para hacernos la vid más facil.
Saludos,
Si tienes que reportar un fallo de la openspa que esta esté en flash ( para todos en general )no por multiboot, cierro el hilo.
